Astra Coupe Haynes manual
Results 1 to 10 of 10
Thread: Astra Coupe Haynes manual
    Feb 2007
    Hants
    Hi guys,
    I'm lloking for a Haynes manual for my mk4 Coupe. The normal one doesn't cover it!
    I need to do a oil and oil filter change asap!
    Someone plz help.
    Sep 2001
    Cavaliers Mk1 Mk2 and Mk3
    Do they even do one for the Mk4 Astra yet?
    Why do you need a haynes manual for an oil change??
    Mar 2005
    South Wales
    Corsa B
    Quote Originally Posted by Brett View Post
    everyone needs to start some where
    Nov 2000
    North Ayrshire
    06 Fabia vRS
    Haynes don't do a manual specifically for the coupe. They do, do a manual for the 'normal' Astra which will suits your needs seeing as they are about 95% similar.
    It will certainly cover you for an oil change as they use the same engines.
    Jul 2006
    south wales
    F**d Transit
    i think i read somewhere that there isnt a manual for the coupe.oops a bit slow therelmao
    I couldn't repair your brakes, so I made your horn louder.
    Nov 2005
    Kent
    There's one for the MK4 Astra, I've got one.
    It covers all engines from 1.6 to LET....or is it 2.2? Can't remember, will check when I get home.
    Jul 2006
    south wales
    F**d Transit
    it doesnt cover the 1.6 8v drive by wire astra mk4 either.
    Nov 2005
    Kent
    Ok, just checked what the MK4 Haynes manual covers...
    Astra Hatchback, Saloon & Estate and Zafira MPV models with petrol engines, including special/limited editions.
    1.6 SOHC
    1.4, 1.6, 1.8, 2.0 & 2.2 DOHC.
    Does not cover bi-fuel, 1.6 Twinport or 2.0 Turbo engines.
    Does not cover Coupe or Convertible models, or new range introduced May 2004.
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    There's 2 Manuals for the MK4 Astra/Zafira. Petrol or diesel.
    The Zafira bodywork isn't overly comprehensive, much like the coupe coverage.
    The engine and mechanicals are all the same.
    Nov 2005
    Kent
    He'll be fine with the MK4 Haynes manual if it's only an oil change providing he has one of the engines covered in it.
