not the final map but a unplanned intermediate map sesh, got a few wierd noises that i can't put my finger on when on boost only, could be pinking or just a cv joint screaming for help done some miles now so might put the boost up to 1 bar and have the cams dialled in, may setup the water injection but it might not be needed at this boost level, also gona ask about swapping to sequential to see if it will need a different map etc ,if not its summat i can do at home and save on labour, not ready with all the other sensors for launch and traction control etc for the full final map, will be in the new year.
@ noble btw
anyone know what sensors i need for the traction control etc (dta) and will the sensor be able to signal off the abs ring ? gona make a bracket and keep the abs sensor std
I Don't know how you'd go about traction control then if all 4 are spinning, as i'd have thought that they'd all be spinning at the same rate, hence the ECU wouldn't know you weren't moving
thats exactly it they never would be spinning at the same rate as percentage of drive to front/rear is different and traction at each wheel would never be equal !
i'm only likely to get all 4 spinning in the wet anyway
i know it seems wrong and that you need wheel spin to even get the rears some drive, but the traction control lets you change how much wheelspin there is, i.e its not "wheelspin detected reduce power until its gone" it can be set at 20% wheelspin then it reduces power above that so your not just wasting rubber on the tarmac and not going any where.
Thinking about it ??? (probably to much lol) could it not be possible to join all the disks within the VC - that way it will be like having the silicone fluid permantly hard ??
Crap way of explaining it as I don't know the techy terms lol
txb aside. just got back from more mapping and fook me i'm grinning like a cheshire cat , no figures this time but boost upto 1 bar, god dam its quick now ,on the motorway ,just put ya foot down for what ever speed you want to be doing and thats it, bonkers fast , forth is devastating , estimate is 300bhp now, obivously i'll get used to this power and there's more to come but it feels so good right now.
Thats basically how vts make a locked box from what i can see. they add more clutch packs so its perminently engauged.
i think i also remember reading that theortically you can fool the ecu by bridging some pins on the 4x4 ecu and make it rwd.
Do noble do live motronic mapping as i drive passed it on the way to my g/f cottage in eyam, and want to tweek my motronic map, and throw out the phase 2 chips.
Am tempted, but if i go the omex route i'd go to northampton motorsport i think. theres been alot of talk of mapping the motronic 2.7 live and over-righting the default map, hense no phase chip, but a proper ecu.
But Aren't Northampton Motorsport rubbish. It would definately be worth the travel to goto Noble
