After reading a post from another mig user, I thought I'd post up the engine spec for an engine I'm having built for a mate of mine
Engine:
2L Xe, Accralite 86.5mm Flat top pistons, Blydenstein head, QED 450 cams, solid lifters, titanium retainers, double valve springs, Steel rods (supplied by rob at RSC) Weber 45's or 48's on flowed inlet manifold, mbe or weber alpha ignition
Steel flywheel with ARP flywheel bolts,
looking for approx 230bhp from this unit,
A few queries are if to use the ARP head stud conversion, and possibly changing the pistons for the high intruder type andmaybe some Tb's if some come up for the right money.
how much difference are wasted valves going to make as were not looking for 250bhp from this engine but I'd like to know if it is neccesary for approx 230bhp
anyones opinions on anything else that you feel is missed out or may be needed would be appreciated
