whats the law in uk on airbags
Results 1 to 14 of 14
Thread: whats the law in uk on airbags
    Jan 2005
    i really want to change the the original s wheel(with airbag) in my nexia but will it fail mot because it wont have an airbag
    thanks
    Jan 2002
    Bradford
    a Crotch Rocket
    Unless the law has changed recently, no it won't fail.
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Air bag is not a testable Item.
    It does not affect the safety of the Vehicle - Just the passenger/driver
    ABS is tetable.
    Glasgow
    saab turbo
    i thought if the warning light was on they could fail you. therefore remove offending bulb. could be wrong tho
    curiosity killed the cat...................but for a while i was a suspect!!
    Mar 2004
    Dagenham, Essex
    Nothing :[
    Quote Originally Posted by Ghost_Walker
    this does work if your tester is abit off as many would not notice the abs unit under the bonnet. however if he did spot it he would then know you have bodged it as the abs is supposed to do a test, when you turn the car on the bulb comes on then goes out when its worked out everything is working.
    May 2004
    NW, England
    Corsa X14XE
    wot about insurance ?
    what view do they take if you have removed airbag ?
    Dec 2004
    Or wire it to your oil pressure light for the ABS light
    Dec 2001
    Chelmsford, Essex,
    Quote Originally Posted by richardmk3
    That won't work, as the ABS light must go out after self test, before the engine is started.
    If you have check control (side+Tail check) or traction control though you can wire it to them
    Apr 2002
    Southwest
    Like its stolen
    Quote Originally Posted by Mark T
    ABS is tetable.
    Seatbelts are testable and are just for the safety of the passenger/driver too
    I think the key thing with an airbag is that it cant realistically be tested anyway.
    Dec 2001
    Chelmsford, Essex,
    Quote Originally Posted by chip
    Seatbelts are required by Law, airbags aren't
    They can't test the ABS either in the test station.
    Nov 2004
    Bedfordshire
    2005 Chevy Silverado
    If Its Fitted, It Must Be Operational.
    If Its Removed And The Bulb Is Extinguished/Removed, No Problem
    Knowledge Is The Bomb - Live The Dream
    May 2001
    52.26320° -0.81374°
    2.0 16v Astra GTE
    Quote Originally Posted by Steve_H
    If you are talking airbags, and that's what the thread is about, then you are wrong. Airbags ARE NOT a testable item for the MOT test. Fitted or not.
    Veni,Vidi,Scubi
    Jul 2002
    Stoke/Leamington Spa
    Whirling Dervish
    AIr bags are not testable but if you remove it then you're insurance can be invalid as your policy will assume it's fitted when you come to claim for personel injury of having smashed you face and chest in on the wheel. just declare it as a modification. The secret is to avoid ever deploying it. they can cause you more damage than they save in certain circumstances anyway.
    "I have nothing to declare"
    Aug 2002
    Near Gt Yarmouth
    Astra Estate
    Only after 1964
    Need custom t-shirts?...www.deathgimp.co.uk
