I meant £90 ish, sorry my mistake, with rgards to fuel pumps that flow even more, im not running silly pressure to my injectors (currently 3 bar), so I would imagine the 053 is up to the job !!! and when I switch over to blues, I will have to run even lower pressure !!!
Its not the pressure, its the amout of fuel it can flow at certain voltages.
Most pumps are bench tested at 14.4 volts and with a head of 1metre.
So with the fuel pump in its normal place and standard wiring don't expect anymore than 11 volts at the pump.
What is the flow rate of this 053 pump then???
I can supply Bosch pumps (the Peugeot 505 has a really high flowing pump and (nearly as much as the 044 motorsport pump) and is a lot cheaper too).
