Right just got my dump valve, t-piece and vacume hose from a guy on mig. Where does the vacume hose from the tip of the valve go to? Also do i need anything else to fit and work properly? A fitting guide will help me loads . cheers guys
pipe that comes from side of turbo, then goes under cover with turbo written (big black plastic/red TURBO )on it on top behind engine
disconnect this pipe from turbo (leave bout 1 inch or leave elbow(90 deg bend pipe) right back to t piece under under the TURBO cover
put pipe from top of dump valve on to this T piece
then use blocking spacer or jus stick bolt in end of old pipe
Ahh, see now I see that picture, mine is the Bailey one, looks exactly like the one abov (not yours Kenny) same piping, hose etc, same blue colour, only diff is that the actual DV is the same as the silver one in your pic.
Mine is a Collins Twin Piston, Bailey fitting kit :beer:
72.7K members
