t-cut alternatives
Results 1 to 8 of 8
Thread: t-cut alternatives
    Sep 2010
    dundee
    1.8 vectra ls
    Smile t-cut alternatives
    hi guys just washed my car as as you can see from the pics it comes up not to bad using just chepo tesco car wash but the paint feels like a bit of sand paper or something
    [IMG][/IMG]
    [IMG][/IMG]
    I was just wondering if there was anything out there that might help with this rough feeling paint. i should mention it could just be the poor paint job it has had before i bought it but i can't remember it feeling this bad before
    cheers in adavnce for any info
    Banned
    Feb 2011
    Re: t-cut alternatives
    T-cut is about as much good as water for paint, get G3 compound on it and use lots of water, it will come up like glass, but you HAVE to polish it afterwards
    MIGClub Member JohnCDX's Avatar
    Jan 2008
    Sittingbourne, Kent
    Corsa1.2 & Octavia 1.9TDI
    I would recommend using a clay bar before proceeding to attack the paintwork with a cutting compound, Bilt Hamber clay is very good and only needs water as a lubricant
    Corsa C12 NZ 1995 and Octavia Estate 1.9TDI 2002
    Jun 2005
    The Isle of Man
    1.3 Chevette L
    Clay it first and then use a mild polish - something that's designed to be applied by hand. I wouldn't advise applying G3 by hand - it's designed for machine polishing and won't break down properly by hand.
    As a rule, try the mildest polish first and see if you're happy with the results before going in with the compound. Something like Autoglym Super Resin Polish is ideal, or anything from the Meguiars range.
    Sep 2010
    dundee
    1.8 vectra ls
    cheers guys, ill pop up to halfords and see what they have
    May 2011
    you might laugh, but for years now i have cut paintwork with either tesco or sainsburys own brand cream cleaner, not as harsh as t cut, needs a bit of effort, about the same as farecla g10 but costs pennies, you do have to either wash well or polish off the residue though but always great results
    MIGWeb Moderator
    Midlands
    Nowt
    Have used Jif etc on white cars.
    Apr 2003
    Birmingham
    Corsa SRi
    throw the t-cut in the bin, it isnt good for anything
    most cleaning product companies make 3 grades of cut, but as already mentioned, give it a good clay and rewash before attacking it with cutting compounds, start with mild, then medium, then hard, then work back down the grades, then finish off with a good polish then wax, meguiars caters for evey stage in this process
    If It Comes Off, Modify It!
    Cruise-Mids.com ~ The Cars, The People, The Scene!
