Mirror polished engine parts starting to tarnish help
Results 1 to 8 of 8
Thread: Mirror polished engine parts starting to tarnish help
    Oct 2009
    Eastbourne
    Nova 2l 16v 1990
    Hi all can anyone help I've got mirror polished parts all over my engine and over the winter where it hasn't been driven the polished parts have tarnished and no matter how much I clean it with metal polish it won't go back to how it was. Can anyone reccomend any product that might remove it and has anyone managed to solve this without getting the parts re-done. Thanks
    Feb 2011
    Re: Mirror polished engine parts starting to tarnish help
    ________________
    Watch TV Online
    Aug 2009
    bristol
    corsa b arden blue
    autosol and then etching laquar apparently
    Oct 2009
    Eastbourne
    Nova 2l 16v 1990
    I've tried the autosol approach which brings it up nice on the parts which are still looking polished but the corroded parts still look dull I was hoping there might be somthing that might eat through that layer.
    If they have started to bad corrode then re polishing is the only way to bring back up. You could try some 1000 wet and dry then auto solve. Auto glym and Megiars both do good metal polish too. They had added wax in too to help repel water.
    Then get a good thick coat of wax over everything.
    Oct 2009
    Eastbourne
    Nova 2l 16v 1990
    I don't think it's that bad yet so I'll give the wet and dry a bash this weekend cheers for the advice
    MIGClub Member JohnCDX's Avatar
    Jan 2008
    Sittingbourne, Kent
    Corsa1.2 & Octavia 1.9TDI
    Autosol and fine wire wool works a treat on chrome exhaust trims so you could give that a try
    Corsa C12 NZ 1995 and Octavia Estate 1.9TDI 2002
    MIGClub Member Turbostevo's Avatar
    Jan 2011
    Chesterfield, derbyshire
    Saabastra/E36328/bora/147
    If your willing to give it a try there's a company called chemetall and they manufacture cleaning chemicals that strip lead based paint off steel down to bare metal! They produce a spray called s71-a and that will probably be the only chemical that might dissolve the layer of scale.
    It's just a suggestion and I'm not going to be held responsible for any damages caused by the stuff cos it's lethal!
    I uses it tonight to remove 15 years worth of grimey oil off an engine block then jetwashed it off and it's done a good job.
    Stevo
