Upon a nova are the door bump strips just held on by sticky strips, Only i dont want to take them off to find out they clip on and have little 4mm holes down the side of the car.
also is the rear nova badges the same ?
When not on axle stands, I'm on boost......
Very early Novas had bumpstrip holes, but most are stuck on with some double sided stuff. All hatch badges are stuck on with no holes too, not sure about saloons but I imagine the same.
the vauxhall badge has holes with the bird holding the V, but the other vauxhall and nova one are stuck on, the paint around it tho will be really fadded and you'll be able to tell by the look of the paint that it had them depending on the colour. also there will be a load of ground in dirt to get off too, quite a task on older cars.
All up to about a D. (so all nova's with no boot handle) had rivet posts to hold side trim clips on.
