Results 1 to 15 of 15
Thread: Anyone polished their cloudy headlights?
    Nov 2007
    I've got a mark 4 astra with a cloudy yellow coloured headlight, does this stuff actually work, anybody tried it?
    VAUXHALL OPEL VECTRA ZAFIRA HEADLAMP HEADLIGHT POLISH on eBay (end time 16-May-10 09:35:19 BST)
    I always assumed it was just moisture or something inside the light, but never actually looked properly, then I saw this stuff. Is it just tcut or something similar? (I have that already ) I will have a proper look at the light and see if it looks like its inside or outside, if it looks outside I might give it a go.
    Oct 2009
    birmingham
    Re: Anyone polished their cloudy headlights?
    that stuff looks pritty good mate, mite get me some lol
    Will just be a compound like g3.
    Nov 2007
    That's what I was thinking, was going to try some stage 1 meguirs or t cut or something and a lot of polishing, but would that give the same effect?
    Jun 2000
    Southampton
    Astra SRi 1.9 CDTI XP 3DR
    I've found Meguiars PlastX to be very very good at making plastic headlamps look like new.
    meguiars plastx, Vehicle Parts Accessories, plastx items at low prices on eBay.co.uk
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    Cheap toothpaste from the pound shop works wonders.....try it.
    J.N.D.Photography@hotmail.co. uk ...weddings, children, pets, cars, landscapes....just ask.
    Nov 2007
    Cheers both, mike will that get rid of the yellow colour? Basically one side has a brand new headlight and the other is original, and loks awful, want to get the old one looking clear and shiny if possible.
    Jamie, really? Just keep rubbing it in? Will that give the effect I'm after? Must be good for the teeth then!lmao
    Jun 2000
    Southampton
    It depends if the damage is on the surface or actually penetrated the plastic. If anything is going to sort it, I'm pretty sure PlastiX will (amoung other things such as minty fresh toothpaste apparently!). If the damage is under the surface, nothing will fix it.
    Nov 2007
    Hmm it looks pretty bad so maybe it might be beyond saving, suppose its worth a go for 8 or 9 quid.
    Searching around I found this, is the sanding necessary or will the PlastiX do a lot of the work? Don't trust myself to not scratch the hell out of the plastic!!!:
    How To: PlastX Headlight Restoration (Step by w/ Pics) - Car Care Forums: Meguiar's Online
    Jun 2000
    Southampton
    Supras with the plastic headlamps (imports - UK spec ones have glass headlamp iirc) suffer very badly from this. If you use "sandpaper", you will need a 2500 grit to finish off, otherwise you will not get them fully clear again. Unfortunately, 2500 grit can be difficult to come by, so you will need to order it online - again, Meguiars sell this. I have some and it is great to use when touching up chips etc.
    Or, any brand on ebay:
    http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    Jul 2009
    Bradford
    Astra Mk4 2.0 DTi
    1200-1800 wd followed by g3 gives excellent results
    Aug 2010
    torquay
    Astra 2.0sri mk4
    My missis had this on her mk4 astra so i used a mop with scratch remover and simple. Its gone. Job done.
    Vauxhall is the only way for me.
    Jan 2010
    Fife
    vxr kitted vec c sri
    Just a thought but would have liked to see the supra after a week or so, mate done this to his and come up excellent and he spent hours on them but after a fortnight were cloudy again.
    Doctors says "IVE CAUGHT OCD".
    Apr 2007
    Lisbon
    Astra Mk3 GSI
    Ya... I also have removed this using 2000 sanpapaper and then yellow pad + menzerna cut compound.
    IMHO products like Meguiar plastic Polish are not enough to remove it
    Apr 2009
    vera, almeria, spain
    cali turbo
    Quote Originally Posted by DrifterX View Post
    Agree, I've tried it too.
