Whats the best way to clean engine bay when engines out.
I cant move the car as its on axle stands and no legs on it
Bit acky after a few oil leaks and road grime and spiders webs/general crap
i would use a steam cleaner first. then wash it with normal car shampoo but use old sponges and rags.
0-60 in........about a minute!
my option would be 5 litres of brake and clutch cleaner cover the floor in newspaper and get a spray pump for spraying the cleaner on and it will wash it off
this will be a messy job whatever way you choose to do it
1994 MK3 ASTRA now with SAAB TURBO power 274.8BHP 315LBFT
INJECTOR CLEANING TESTING 24HRS TURNAROUND
WWW.SAABCONVERSIONS.COM
Previously known as Astra-nige
cover all your electrics and sensors with tin foil or cling wrap or somthing like that and then spray the whole engine bay with gunk or brake cleaner and rinses of with a hose, then finish up after its dryed with autoglym rubber and vinyl care on the blacks or use instant tyre dressing by autoglym on the plastics/blacks
Because I'm a complete nutter I would stand there with the pressure washer on dirt blast lmao lmao
astra 2002 sxi spare parts 07521382540 wheels, cd player cdr500, lights, seats, door cards, white dials, exhaust, suspension, breaks. spoiler. wiper motors, wiper arms.
GUNK
Gunks is sh*te, get a good de-greaser brush it all over neat.
Then use a jet wash to wash it all off, then normal shampoo after.
If it is really bad an initial brushing with paraffin (before the degreaser) letting it soak in can help loosen the thick bits.
I'm with you on that, soo many times I've driven my car away with steam piling out sounding like an impreza YEAAAAAHHH!!!
my 2p? I like gunk engine degreaser but it's pricey, you can buy huge containers of real cheap nasty degreaser from the likes of wilkinsons and other cheap hardware shops ( the type you wouldn't find yourself normally entering)
Oh yeah a drop of water around the spark plugs leads dizzy or coil pack never hurt anyone lmao lmao
in my corsa i used elbow grease spray from pound land lol sounds like a no hoper but worked extremly well
then steam cleaned off after leaving for 3-4 mins
