window screen rubber
on my astra mk3 for some reason the window screen rubber that run along the top of the window & sits on the roof has decided to lift up off the roof (will get pics asap) what can i use to stick this back down with out making a mess over the paint & body work ???
Re: window screen rubber
they are a pain! not easily put back without taking the screen out!
You could always try some clear siliconce, its a bodge but may work!
I tried using clear silicone to re seat the sunroof seal on the wife's Saxo, I got in such a mess with it, I ended up sealing the roof permanently shut.
