Advertise Here - Click for More Info
Go Back   MIG Performance Vauxhalls > MIG Technical > Car Cleaning and Detailing
Car Cleaning and Detailing Post any cleaning and detailing questions here. Also use this forum for "Just Cleaned My Car" photos.
Old 01-07-2009, 11:35   #1
MSG
Drives: Calibra 16V 2L P Reg
what is the best way to Cleaning my calipers and paint?
As i am in the middle of renovating my front brakes, new discs, etc, it about time I also cleaned my rusty looking calipersb and have them painted as they do show considerably through the wheel spokes,
how best to clean them? remember I haven't got access to shot or sand blast machines, can I use just a wire brush mounted ina drill and remove as much rust as possibble and then spray pain one of them 500deg C temperature resitant paint, and what coulour would look best for my Green Calibra? yellow would certainly go with green, but how about red? I don't have to pain the inner side just the outer that is exposed to the sight from the outside.
ideally i would not like to disconnect any hydraulic pipes, hate beleeding, mind you I also need to change the fluid to new one any way.
Scientists must be so dumbos, if they can't prove the existence of God, the evidence is everywhere, they just can't figure it out! God help them!
MSG is online now   Reply With Quote
Old 01-07-2009, 15:13   #2
MSG
Re: what is the best way to Cleaning my calipers and paint?
LOL!! Nearly 4 hours and I take it the answer is leave the cleaning and painting the calipers alone unless I am gay!! or going for Brambo 4 pot calipers!!! that would be double gay!! lol
Old 02-07-2009, 15:02   #3
cheekyalex
Drives: a p.c with wheels
wire brush on a drill does a great job. Just make sure you got good eye protection on!! and just get some hammerite, dont bother with high temp spray, brush on hamerite will easy last a good few years and withstands the temperature just fine from my experience. gives a grat finish and is easy to apply too.
Want good quality mirror finish smoked rear lights for you car? drop me a pm.
cheekyalex is offline   Reply With Quote
Old 02-07-2009, 15:17   #4
MSG
I recently bought some grey hammerite pain for another application (painting some warm air ducting work) due to corrosion attack, I followed instructions on the can not to stir, but still the paint outcome was flat, it did not have that special hammerite effect like ripple effect.
What colour would you suggest,yellow or blue or red?
Old 02-07-2009, 15:30   #5
Dav1d
Drives: Bmw 3 series
It wasn't Hammerite smooth was it ?
Dav1d is offline   Reply With Quote
Old 02-07-2009, 16:01   #6
MSG
It might have been, I got a small tin from halfords. I have it somewhere and have a look if it was. It came out same as a normal paint finish i.e. smooth instead of the usual hammeritr effect.
Old 02-07-2009, 16:04   #7
Grim Reaper
Drives: steve!'s bwm :D
hammeright has 2 different sytles, smooth and the normal one which is all crackly and looks like powder coating just go for smooth on the calipers and use a wire brush on a drill (like alex said)...if you can remove the caliper is even better, otherwise just unbolt and move it off so that you dont have to rebleed the system and also paint the back too
i sendz warningz...i haz uber phailz. How duz the dipstik werk????111!
Grim Reaper is online now   Reply With Quote
Old 02-07-2009, 16:24   #8
libra
Banned
Please dont do it yellow, or red, I think you should go for the colour your car is, I dont want to say it as its a colour that I dont think should exist! lol
Or even better idea, paint the calipers red, then the rest of the car to match it too? Il even give you a hand?
libra is offline   Reply With Quote
Old 02-07-2009, 17:39   #9
Grim Reaper
@ libra
if your not after showyness then just paint them black or that grey colour you said you had
Old 02-07-2009, 18:16   #10
Ian H
Drives: Corsa C
if your replacing the disks and pads anyways just splash it on now, give it a really good coat and doesnt matter if you go on the disk seeing as your replacing them anyways!
i would go black, no point making small standard brakes stand out imo
Ian H is offline   Reply With Quote
Old 02-07-2009, 18:53   #11
MSG
Originally Posted by Grim Reaper View Post
@ libra
You know why, cause he has a red car!!
Old 02-07-2009, 19:12   #12
Benn
MIG Regions / South Central Regional Coordinator
Benn's Avatar
Drives: A shineeeey Let Nova
Just do the smooth silver, makes them look new.
Man I just stopped caring, the music is blaring
I feel you glaring, why wont you stop staring?
Old 02-07-2009, 19:16   #13
MSG
Good idea mate, I will order that colour in high temperature (500deg) I like silver it will be neuteral, I don't know why I never thought of it in the first place. cheers Benn.
Old 02-07-2009, 19:18   #14
MSG
Yes I was thinking of doing the wire brushing while it is still bolted on solidly and I can use both hands to grip the drill and guide the wire brush around,since the old discs and pads are going to be discarded any way.
Old 02-07-2009, 19:18   #15
Benn
Benn's Avatar
Just by hammeright.
You dont need anything else. Hammeright take the heat fine.
Old 02-07-2009, 19:40   #16
MSG
Just by hammeright.
Thanks again. I rememeber someone posted the goodness of using white vinegar to remove rust, so I was condsidering possibly dipping the calipers in vinegar having taken out the pistons and other rubber components, that vineagar cleaned a rusted part and turned it into a brand new looking and then it can be painted andn the paint is likely to not flake out!!
But I must try that vinegar magic first on something rusty to see if it really works as claimed.
Old 02-07-2009, 19:45   #17
Grim Reaper
just wire brush them you poncy ninny! just making extra work for yourself by dipping them in viniger when a wire brush works fine...
Old 02-07-2009, 19:52   #18
libra
Banned
Lol dipping them in vineger
If you want something different gold plate them, or just gold.
Yeh reds the best, blacks ok too. Athough one of my friends thinks my car look "pink" in the sun!
Old 02-07-2009, 20:01   #19
MSG
I always wanted to paint my wheels Gold, as in subrus, they really go with them cars. And I am sure they can go well with my green calibra.
Old 02-07-2009, 20:09   #20
libra
Banned
I duno, Im not a fan of any wheels that arent crome or silver. I dont mind the black with outer steel on black cars, definitly not a fan of white wheels! lol
If you painted them gold they might not go with your yellow or red calipers! lol
Old 02-07-2009, 20:10   #21
Grim Reaper
green calibra??? gold wheels??? red calipers??? is you be colour blind??
Old 02-07-2009, 20:21   #22
libra
Banned
Maybe he watches Ugly Betty and them colours are in fashion?
Old 02-07-2009, 20:22   #23
MSG
Not going for red calipers, I decided to keep them silver to go with my silver wheels, but they can be painted gold if my wheels were to go gold.
Old 02-07-2009, 20:23   #24
Benn
Benn's Avatar
Red? Wtf.
Use a wire brush, and do them silver. Silver is for kings.(and you if you do it)
Old 03-07-2009, 00:28   #25
Dexy
Dexy's Avatar
Drives: Vectra GSI + Cav SRI
Red? Wtf.
silver? maybe ftmfl
Hammerite hammered black finish is the boy.
Msg" Wire brush and hammerite paint. simples.
XBOX 360 GAMERTAG - Derekmack
Dexy is offline   Reply With Quote
©MIGWeb 1997-2009 - MIGWeb Home - Archive - Privacy Statement - Top
Powered by: vBulletin. Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
