Larger discs would naturally mean the calipers will have to be replaced to suit the larger diameter, but what I am not sure is if these larger calipers will fit to the same leg or the carrier mount holes,
I beleive I have often heard people say on here that you need to change the carrier/leg for the larger discs, and then the problem with larger discs is that they will need drilling to accomodate 4 studs wheels as the larger discs are for 5 studs.
I am not keen on drilling largere discs with more holes to convert to 4 studs as the more holes you drill the weaker the hub assembly must become.
Ultimately, if I go for bigger discs then I will also end up buying 5 studed wheels, so it will be more unnecessary expense. so for now l will have to put up with these silly little discs for the time being.
They will probably grow on me!! lmao
