xe cam cover best way to remove old paint
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 27
Thread: xe cam cover best way to remove old paint
    Feb 2008
    weston-super-mare
    20xe mini + 20xe corsa b
    hey i want to bring a old xe cam cover back to ally to paint it again as areas have flaked off of the old paint ive tried removing it with a wire brush sandpaper a wire brush on a drill paint stripperand
    heating it up and using a scraper but its just not shifting it anyone have any tips cheers james
    Jun 2009
    Lincoln
    Corsa B 1.0 12V
    Re: xe cam cover best way to remove old paint
    try nitromors mate, its probably the best stripper out there IMHO
    Mar 2006
    Kent
    Got mine stripped at a place that re-furbs alloy wheels, they put it in their acid tank for a few mins and it came out better than you will ever get it!! Ive tried the nitromors route before, nightmare IMO.
    Jun 2009
    Lincoln
    Corsa B 1.0 12V
    Quote Originally Posted by DragXE View Post
    why did you find it a nightmare, just brush on leave and then wire brush wheel off
    Jan 2002
    southampton
    sm2'd, T3'd let nova
    Agree mate, the standard coating is a mare to remove, nitromorse did not touch it in places, had to take it to work and bead blast it, as the nitromorse left it in a right state!
    [quote]The Simps;
    If you find the water leak and its a hole that needs welding up gimme a shout[QUOTE]
    Feb 2008
    weston-super-mare
    yeah thats what ive tried (nitromorse) cheers guys ill get it blasted in my dads sand blasting tank cheers james
    Nov 2006
    ramsgate
    car
    Quote Originally Posted by fatboi567 View Post
    You obviously dont mind a **** job
    Jul 2003
    Cumbria
    Pug 106 & VW T4
    Laddo at work had an XE cam cover that he wanted to strip back to metal, shot blasting it took all the loose flaking bits off but wouldn't really budge the rest of it, he ended up using NitroMorse, had to put a good few coats on it tho to get every last bit off.
    Looked a pain in the ar*e to do !!
    No longer the owner of an LET'd Nova ... Good times !!
    Jan 2002
    southampton
    Your right Rich, bead blasting it has still left me with bits of coating! had another go tonight, still no joy! will break out the nitromorse again to remove the stubborn parts! acid tank would be ideal.
    [quote]The Simps;
    Aug 2006
    huntingdon
    E46M3/GSXR750/RWD SCOOB
    Quote Originally Posted by merijaan View Post
    Buy another one?
    Ahh so its you that has all the mint cam covers hidden lmao how much are they?
    Jan 2002
    southampton
    Tried myne again with a heavey solvent, no joy as now the coating on the inside is flakeing! going to get it acid dipped so i know its all been removed.
    [quote]The Simps;
    Jul 2000
    In Gavs shadow...
    Vectra VXR Estate
    From some one who has stripped and polished countless covers. Acid dipping is the only way...
    Jan 2002
    southampton
    Thanks Jimbo
    [quote]The Simps;
    Jan 2003
    Beverley, East Yorks
    Nova 2.0 16v turbo
    Acid dipping gets my vote (this is how mine was done!)
    Bead/sand blasting could leave lots of little bits in the rocker cover which once fitted will get into your oil and jigger your engine rather quickly.
    Joff
    I don't do standard!
    (Nova Turbo rebuild now finished)
    Jan 2002
    southampton
    Got myne done in the end, went over to a lubes unit at work and got them to run me off some nmp from the bottom of a tower at about 70deg! soon shifted it! one more bead blast sesh followed by alot of cleaning hp air blowing etc!
    [quote]The Simps;
    Feb 2006
    Berkshire
    Astra mk3 1.4 est.
    defo
    THAMES Valley Porsche Club
    Astra Mk.3 1.4 GLS Estate
    944 S2 Cabriolet ( 208BHP / 211ftlbs )
    Feb 2008
    weston-super-mare
    in the end as it wouldnt fit in the blast tank i used nitro morse and one of those flappy attchments you put on anglegrinders it shifted it no worries cheers for the help guys
    ps next time its goin strait to acid dippers
    clean cam cover and no hassle lol
    Feb 2005
    Surrey
    Astra Hatch MK4 2000
    Quote Originally Posted by dan-j View Post
    I would have just put more nitromors on.. in a thicker coat and left it to do its job.. but if never get everything off
    Jan 2002
    southampton
    I tried the nitromorse as you have said a fair few times, trust me, it would not shift alot of the std powder coat! it was solid.
    [quote]The Simps;
    Nitromorses will struggle against power coating.
    Sep 2009
    Sheffield
    i take stuff to work and send it down the ovens to burn all the crap off, then grit blast it, works fines with everything usually, if its not coming off just turn the pressure up a bit
    Sep 2008
    Alness
    Let Corsa, golf gttdi
    i used nitromorse on mine what a mess but it worked but still need to get it blasted to get the edges. the powder coat is tough
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Soda Blasting Specialists - EcoBlast UK Ltd
    I used these guys, it's like sand blasting with out the sand
    Came up really nice, and you don't have to worry about sand in your oil
    Feb 2006
    Northampton
    Mk1 Van/Mk3 Van
    Anyone used caustic soda? probably got more punch than nitromors
    Mig Performance Iron ore Mining
  26. #25
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    I did nitromors and then wirebrush on a grinder.
