Aerosol Spray Cans
Results 1 to 11 of 11
Thread: Aerosol Spray Cans
    Mar 2006
    Highlands
    Astra's & Nova
    Aerosol Spray Cans
    Does anyone know how many Aerosol Spray Paint Cans would be needed to paint a Front Bumper, Wing and Door..
    Vehicle : Nova GSi (Star Silver)
    Halfords do them but i am unsure if it is the correct one and what like they are, any help..?
    CLICKY
    Also how many Aerosol Spray Lacquer Cans would be needed and what would be the better one to go for..
    CLICKY
    I haven't got the foggiest as you can see..
    Vauxhall Power....
    Aug 2005
    Hull
    Vectra SRi 2.0 16v
    Re: Aerosol Spray Cans
    3 or 4 cans per panel should get you 2 coats of silver, same again for the clear. If you're doing the inside of the door aswell you may need an extra can or two of each.
    I did rear panel, both rear arches, both sills, one door and a pair of front wings with rattle cans a few years ago on my old SR and got through at least 30 cans, and that was without any lacquer! Emptied the 3 local hally's (2 in hull and 1 in beverley) and ended up traveling to scunny, goole and brid to deplete their stocks!
    Sep 2007
    Isle of lewis
    Astra van
    You dont really want to start spraying a car with rattle cans, if its half decent!
    MIGWeb Moderator
    Midlands
    Nowt
    Agreed, unless your super skilled!
    Sep 2007
    Isle of lewis
    Astra van
    Paint for the gun can be bought that cheeply now it aint worth using aerosols
    Feb 2009
    London, Middlesex
    Corsa LS
    Well i havnt sprayed my bumpers as of yet, so this is coming as an estimate, but i would say 5 - 6 cans ... depending on a number of factors, one factor is how good you want it to be... in other words if you want it to be real colourful and shiny ... you will need a number of coats.... meaning more cans of spray.
    Apr 2009
    leeds, west yorks
    mk3 astra merit xe
    rent a cheep compressor and get cellulose, sur halfords do it in litre tins for 15 quid,
    that should be more than enough basecoat as you thin it down.
    hope this helps
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    Quote Originally Posted by Dell Balallan View Post
    to be precise, youll get maybe 2 500ml (like **** is there that much inside) cans for under £15 when you can get a litre of 2k for around a tenner, which is in fact ONE litre that thins down to about 2 litres and you get about 5 times more coverage than with a rattle can.
    i use rattle cans to do spot repairs where a small section needs blowing in then laquering over, id never recomend its use for anything other than that and small bolt on parts i.e. grills etc
    Jan 2008
    Bramley Leeds
    mk4 astra sri c20let
    mite aswell get roller and brush out if your going to use rattle cans
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    realistically, your as cheap spraying it using a proper spray gun. metalics from spray cans arent easy, as the metal flakes buld up in the nozzle and come out uneven, making the paint look cloudy.
    rattle cans are fine for small things like door handles etc, Soild colours arent bad if you really put the effort in and flat the primer, flat the paint using 2kgrit wet paper, then polish it
    Nov 2008
    North Wales
    What Ive done is spray the panels with primer (cheap enough £6.99 a litre from halfords) flatted it down and then got my brother in law to spray the colour the proper way.
