31-07-2008, 21:17
#1 | | MIGWeb User
Join Date: Jul 2008 Location: newry n.ireland Drives: 93 calibra 2.0i 8v
| polishing my engine? i hav a engine that im going to put in my cally but while is still out of the car i was thinking of polishing the whole engine+gearbox anyone got some info like what would be the best stuff to use +tips |
31-07-2008, 21:22
#2 | | Regional Co-ordinator
| Re: polishing my engine? Block would be a nightmare cause of getting in to all the small/hard to get to bit,
the gear box isnt much better, you'll need to sand everything smooth first, then best off looking on ebay at metal polishing kits.
Tip wise, sand sand and sand.. till your doing to 1000 grit paper.. then strat buffing on a corse wheel then med then finest wheel.
__________________ Quote: |
31-07-2008, 21:39
#3 | | MIGWeb User
Join Date: Dec 2005 Location: Solihull, W.Midlands Drives: 118d,G1.8SE2,C1.2SXi
| Re: polishing my engine? The best way to do it would be to CNC the outside of the block to create smooth planar surfaces, then strip the gearbox and take both to someone with a vibratory polisher. Then you'd have to lacquer it to keep it shiny.
Machining - £200-400
Polishing - £100
Lacquer - £20
Shiny engine - priceless.
__________________ Selling - PC and lots of meg's cleaning stuff, random z18(xe / xer) and z16(xe / xep) parts. |
31-07-2008, 21:42
#4 | | Regional Co-ordinator
| Re: polishing my engine? Gonna do my gear box. |
29-08-2008, 18:08
#5 | | MIGWeb User
Join Date: Dec 2002 Location: London Drives: 400 BHP Skyline GTR
| Re: polishing my engine? Quote:
Originally Posted by MarkyG The best way to do it would be to CNC the outside of the block to create smooth planar surfaces, then strip the gearbox and take both to someone with a vibratory polisher. Then you'd have to lacquer it to keep it shiny.
Polishing - £100
Lacquer - £20
Shiny engine - priceless. | any pics of a cnc'd engine block?
__________________ My Skyline for sale, PM me or see for sale section. |
30-08-2008, 20:50
#6 | | MIGWeb User
Join Date: Jul 2008 Location: nr Derby Drives: V8 Senator
| Re: polishing my engine? Get a wire wheel drill attachment and clean the block and box up.
Then paint in a decent bright silver paint.
It's much easier than polishing and looks almost as good |
30-08-2008, 21:02
#7 | | MIGWeb User
Join Date: Apr 2008 Location: maidstone Drives: cavalier 1800 lsi
| Re: polishing my engine? I would imagine that it would be a bugger to keep it looking polished |
30-08-2008, 23:45
#8 | | Regional Co-ordinator
Originally Posted by Agent Kellerman Get a wire wheel drill attachment and clean the block and box up.
It's much easier than polishing and looks almost as good | Polished will allways look better.. Quote:
Originally Posted by 1800lsi I would imagine that it would be a bugger to keep it looking polished | Lacquar it and it would stay looking shiney... |
31-08-2008, 10:58
#9 | | MIGWeb User
Join Date: Mar 2002 Location: Reading, Berkshire Drives: Omega & 1.8 Corsa B
| Re: polishing my engine? I doubt there is a lacquer available that you can use at those temperatures with out it bubbling, cracking or going yellow. |
09-09-2008, 15:57
#10 | | MIGWeb User
| Re: polishing my engine? I found a tin of high temperature engine laquar in my Garage made by car plan have a look in halfords matey |
09-09-2008, 15:58
#11 | | MIGWeb User
| Re: polishing my engine? I'd give it 10 minutes before it started yellowing and peeling off. |
11-09-2008, 14:22
#12 | | MIGWeb User
Join Date: Feb 2008 Location: Newcastle (ish) Drives: Astra SXi (MK4)
| Re: polishing my engine? halfords do high temp engine laquer. its made by gunk and works. i polished my engine and put that over the top and it hasnt bubbles/flakes/gone yellow.
I would never do it again tho. it took hours to get a good finish, unlimited ammounts of autosol and you need to clean it every 5 mins to keep it shiney. since ive done mine its been a complete pain in the arse and adds a good 30-40 mins on the time it takes to clean the car cos the engine bays gotta be done aswel.
Having said that when its clean it looks fantastic
__________________ "I'm not even gonna lie to you mate, with the fumes coming out of my car I spend most of the day V-Powered off my tits" |
11-09-2008, 18:26
#13 | | Regional Co-ordinator
Originally Posted by Carneyste halfords do high temp engine laquer. its made by gunk and works. i polished my engine and put that over the top and it hasnt bubbles/flakes/gone yellow.
Having said that when its clean it looks fantastic | Pics? |
11-09-2008, 20:50
#14 | | MIGClub Member
Join Date: Jul 2000 Location: Muppetsport Dojo Drives: The wife up the wall
Originally Posted by Benn Pics? | Funk yeah I want pics to.....
__________________ Clicky link for rebuild thread..I am the 5th dan black belt grand master of the sacred dojo of "Muppetsport" Wax on, wax off, Engine out, engine in.......Quote: Daley..My funking helmet STINKS man! |
14-09-2008, 00:30
#15 | | MIGWeb User
| Re: polishing my engine? ill give it a clean next time i do the car and get some uploaded. im not off again until next monday so you may have to be paitent lol |
14-09-2008, 00:55
#16 | | Regional Co-ordinator
| Re: polishing my engine? Benn doesnt do paitent. |
14-09-2008, 10:18
#17 | | MIGWeb User
| Re: polishing my engine? no need to go to 1000 grit, upo to 400 - 600 will do then go to emery compound then green then white. Tbh it isnt worth the hassel. I do polishing myself doing xe covers and bmw stuff and this would be a pain in the ars of a job.
The £100 polishing isnt realistic either as i do inlet manifolds for £150 and a engine blocks so much more work. Any polisher would hum n har about doin it i would of thought.
Plus whats the block made from? if its cast iron then thats more of a problem too |
Members: 43,218
Threads: 310,630
Top Poster: LEE69 (43,150) | | Welcome to our newest member, tomo_se4 | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
