I got some black colour replacement t-cut for the gsi the other day, now a friend told me not to.
The colour is diamond metallic black.
If not, then what do you use ?
Thanks.....Daz
Thanks.....Daz
i'd use g3 then a nice heavy coat of wax at this time of year
Ta ta Vauxhall,
Helooo shexy focus ST
What do you want to do? Remove the haze?
If so then t-cut is fine just for those swirly scratches that all cars have
Originally Posted by wayne451
T-cut is pretty useless on cars with metalic paint as we all know there laqured. As above a once over with G3 rubbing compound and a good wax should give you a good result.
Just want to rid of the oxidents in the paint , and the guy used to run the car through a carwash , so theres miner scratches .Originally Posted by Chavtastic
I just need to know if its safe to use t-cut .
A friend told me that on metallic cars it can leave dull spots. Is this true ?
I've used the colour magic stuff and it's worked brilliantly on metallic. Mine's a pearlescent too and it's fine. In fact, I used most recently the Halfords "safe cut" and that was even better. Left it looking like it had just been sprayed
Cheers chavOriginally Posted by Chavtastic
Turtlewax colour match.....you get a little chipstick lipstick for touch ups (oooeerrr missus)
Goes well on the laquered surface
That is 1 shiny muddaOriginally Posted by angryman
I'll get some of that ....cheers
Aye thats nice![]()
