21-08-2005, 22:03
#1 | | MIGClub Member
Join Date: Jan 2005 Location: Ireland Drives: Cars you won't like
| Reconditioning paint work At 11 years old, my car looks quite good for it's age... however of course it's starting to look a bit dull in places.
It does have the odd scratch and score, but nothing too serious (besides the rear arches... but thats a story for another thread).
Anyway, with the age and value of the car, and my finances, a total respray is out of the question. That said, I would like to try and spruce it up a bit. Are there any particular products that you guys use to bring out the shine on things ?
I wash it pretty regularly with this standard tescos car shampoo with polish included... and it does look quite nice and shiny for the first day or 2 after a wash... this soon dulls though. Any advice for bringing it out a bit (relatively cheaply), would be appreciated
Anything on restoring the bumpers and plastic a bit wouldn't go amiss either
I know some of you guys have cracking looking motors from what I've seen in pics
__________________ Feckoff cup! |
21-08-2005, 22:10
#2 | | MIGWeb Moderator
Join Date: Apr 2005 Location: coatbridge Drives: carb'd xe nova
| best thing to do is use farecla g3 compound rub, use this with an orbital buffer, once you have done that do the same with farecla g10 with the buffer, once you have done this then go over the car with t cut
__________________ Quote:
Originally Posted by Lugy Theres a boy outside riding a unicycle. How bizarre lmao | |
21-08-2005, 22:13
#3 | | Regional Co-ordinator
| tcut and a buffer will do a lot,
or ag's tcut stuff(paint renovator)
and on bumpers,theres lots of different ways
i useda black to black gel stuff,gave the bumpers a freash black clean look,
then added a'g's bumper care over the top,
or the megs trim stuff,(found it a lil better in places)
__________________ Quote: |
22-08-2005, 10:58
#4 | | MIGClub Member
| Cheers guys, will give it a go  |
22-08-2005, 13:00
#5 | | MIGWeb User
Join Date: May 2004 Location: Northern Ireland Drives: 1.2 8v corsa
| meguiars 3 stage cleaning polish and wax.
top top job.
lot of work but well worth it! |
22-08-2005, 16:24
#6 | | MIGWeb User
Join Date: Nov 2004 Location: Huntingdon Drives: Opel Astra 180iE
| Quote: |
Originally Posted by tarmac chewer best thing to do is use farecla g3 compound rub, use this with an orbital buffer, once you have done that do the same with farecla g10 with the buffer, once you have done this then go over the car with t cut | Surely that's bad idea?
I would have though T-Cut to be stronger than the first 2 products you suggested - thus it would go straight thruogh them and start taking more paint away, rendering all the previous work pointless? |
23-08-2005, 12:39
#7 | | MIGWeb User
Join Date: Dec 2002 Location: nottingham Drives: 2.0L cav
| Quote: |
you think T cut is stronger than G3 cutting paste???
Tarmac chewer is correct with what he has suggested in that order
although it will need a good polish and wax, after the TCUT
__________________ ******WANTED*********
Lowering springs for a mk3 cav
-40mm for Non IRS |
23-08-2005, 16:59
#8 | | MIGWeb User
| Quote: |
Originally Posted by *AJ* Tarmac chewer is correct with what he has suggested in that order | I take it that means it's not then?
I've got the same situation with my car, have used T Cut original on it a couple of times now, i would have thought that kind of paint stripping power would be more than strong enough? |
23-08-2005, 18:37
#9 | | MIGWeb User
| G3 is stronger, its usually used after spraying to get rid of the orange peel affect
not recommended for normal use, but if the paintwork is bad, the stuff is amazing!!!
its cuts back a layer of paint, and usually gets back to the original colour |
23-08-2005, 18:53
#10 | | MIGWeb User
Join Date: Oct 2001 Location: Herts Drives: Grale, Mustang, 535i
| I wouldn't be surprised if T-Cut is coarser than G3. It is definately coarser than G10. Don't forget it is designed for hand use, not machine use whereas the Ferecla products are designed for machine use.
I would go with G3, then G10 (by machine) and finally give it a hand wax with Meguires Gold Class wax.
From then on wash it regularly with a decent shampoo and re-wax each time. If it starts to fade again after a few months give it a hand polish with something like Autoglym Super Resin Polish before the wax.
Mike |
23-08-2005, 19:13
#11 | | MIGWeb User
| Is this G3 stuff better than Meguires Dual Action Cleaner Polish? |
23-08-2005, 19:26
#12 | | MIGWeb User
| G3 and G10 are generally used by bodyshops. Because of that they are designed for use with a machine polisher. If you plan on using a machine polisher then these are probably the best.
If you are going to polish by hand, then products like the Megs may well be better as they are designed to be used by hand.
Mike |
24-08-2005, 12:09
#13 | | MIGWeb User
| Quote: |
Originally Posted by Mike007 G3 and G10 are generally used by bodyshops. Because of that they are designed for use with a machine polisher. If you plan on using a machine polisher then these are probably the best.
Mike | you can mop a car by hand using G3, but make sure you mix it with water, otherwise you could end up in a mess  |
24-08-2005, 16:38
#14 | | MIGWeb Moderator
| its what i we use in the bodyshop, usually once a car has been painted i go over it with g3 on a wet cloth and then buff it into the car, then the same step is done with g10 which is a lighter and finer grade |
24-08-2005, 17:15
#15 | | MIGWeb User
| Yes, you can use it by hand, but it is designed for use with a mop. I wouldn't worry about using a mop-designed polish by hand, but I wouldn't use a hand polish with a mop (such as T-Cut). Companies like Ferecla spend a long time perfecting the properties of their machine polishes.
Mike |
Members: 43,160
Threads: 310,452
Top Poster: LEE69 (43,139) | | Welcome to our newest member, 13ig13oy | | » Join MIGClub Today | Join online
now!
of being a MIGClub Member.
